发布时间:2024-04-08 12:28:50 浏览量:229次
实现类似于浏览器打开多个网页的效果,可同时查看网站的多个页面。
1.添加tabs标签页
其中<p v-html=item.content></p>是为了防止Html转义,使其能够在页签中显示网页而不是字符串。
<el-tabs v-model="editableTabsValue" type="card" closable @tab-remove="removeTab">
<el-tab-pane
v-for="(item, index) in editableTabs"
:key="item.name"
:label="item.title"
:name="item.name"
</el-tab-pane>
</el-tabs>2.data中添加默认页面,这样不至于打开网站之后是空白。
editableTabsValue: '1',
editableTabs: [
title: '员工管理',
content: "<iframe ref='1' width='100%' height='850px' src='page/member/list.html'></iframe>"
tabIndex: 13.methods中添加js脚本,用来关闭和添加页签
关闭页签
removeTab(targetName) {
let tabs = this.editableTabs;
let activeName = this.editableTabsValue;
if (activeName === targetName) {
tabs.forEach((tab, index) => {
if (tab.name === targetName) {
let nextTab = tabs[index + 1] || tabs[index - 1];
if (nextTab) {
activeName = nextTab.name;
this.editableTabsValue = activeName;
this.editableTabs = tabs.filter(tab => tab.name !== targetName);
}导航中的单击事件中添加页签,如果已添加则无需添加直接打开
//动态添加标签页
//首先判断是否已经打开
let findActive = 0
if (tab.name == item.id) {
this.editableTabsValue = item.id
findActive = 1
if (findActive == 0)
this.editableTabs.push({
title: item.name,
content: "<iframe ref=" + item.id + " width='100%' height='850px' " + " src=" + item.url + "></iframe>"
this.editableTabsValue = item.id;
//////导航的html如下
<el-scrollbar wrap-class="scrollbar-wrapper">
<el-menu
:default-active="defAct"
:unique-opened="false"
:collapse-transition="false"
background-color="#343744"
text-color="#bfcbd9"
active-text-color="#f4f4f5"
<div v-for="item in menuList" :key="item.id">
<el-submenu :index="item.id" v-if="item.children && item.children.length>0">
<template slot="title">
<i class="iconfont" :class="item.icon"></i>
<span slot="title">{{item.name}}</span>
</template>
<el-menu-item
v-for="sub in item.children"
:index="sub.id"
:key="sub.id"
@click="menuHandle(sub,false)"
<i class="iconfont" :class="sub.icon"></i>
<span slot="title">{{sub.name}}</span>
</el-menu-item
</el-submenu>
<el-menu-item v-else :index="item.id" @click="menuHandle(item,false)">
</el-menu-item>
</div>
</el-menu>
</el-scrollbar>
