发布时间:2024-06-15 16:53:31 浏览量:241次
现如今,OpenAI的聊天机器人ChatGPT成为热议话题:不仅可以写代码、写诗,还能结合各种软件和插件来进行绘图设计、计算、音乐等工作,其功能之强大让许多人担心工作将被人工智能取代。
Curious about the capabilities of ChatGPT? Let's see if it can unveil the appearance of the next-generation flagship graphics card!
Do you remember the GEFORCERTX 4090TI unveiled at the 2024 Chinese Spring Festival Gala? What are your thoughts on this graphics card?
How do you think the design of the next-generation flagship graphics card should be? What design would make the appearance of the flagship graphics card appealing?
Can you describe the appearance of the future flagship gaming graphics card?
When we lack a clear impression of the next-generation flagship graphics card from ChatGPT's answers, we can use the AI drawing software Stable Diffusion to transform ChatGPT's responses into images.
Stable Diffusion is an AI drawing tool that can be deployed on home computers, with a high demand for graphics cards, requiring at least 8GB of video memory. Here, we used the 映众4070TI Ice Dragon for productive work.
Simply input ChatGPT's responses into the software's image description, set the corresponding image requirements, click create, and wait for the output. It's that simple.
During the production process, you can see that the video memory consumption reaches around 12GB. The larger the output image, the higher the graphics card requirement; and the graphics card performance determines the output speed. Therefore, it is recommended for players to use a graphics card of at least 4070TI level or higher. In contrast, the software does not place a large demand on the CPU.
The software can be set to output multiple images at once. If you are not satisfied with the output, you can continue creating until you get a result you like.
Upon finalizing the images, the results look quite impressive at first glance, definitely much better than what a clumsy editor like me could draw! For professional designers, such creations provide fresh ideas and serve as a basis for further artistic work based on the images generated by AI.
Here is a performance comparison of mainstream graphics cards in Stable Diffusion, making it easier for everyone to choose the right graphics card product.
